はじめに
This guide is to replace a broken screen on the Nexus 6.
必要な工具と部品
With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
Remove the SIM card and the SIM card holder.
この手順で使用する道具:iOpener$12.99
Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
Pry open the back casing using the soft plastic opening pick.
Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
With tweezers, remove the rubber protector on the lower part of the phone.
Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
With a spudger, unlatch the ZIF connector for the smallest ribbon cable in the center. See instructions for detatching ZIF connectors here
Use tweezers to release the ribbon cable.
80 の人々がこのガイドを完成させました。
8 件のコメント
its not antistatic tape its actually just Kapton tape and its ment only to protect the ZIF housing and keep the tabs from accidentally opening while being assembled along the line
Is there any way to buy just the digitizer if so where and how much
The digitizer and screen are a single unit. You can usually find the screen/digitizer for around $135-$140.
Si può sostituire solo il vetro esterno o tutto il display?
