メインコンテンツにスキップ
はじめに
This guide will show you how to replace your Nexus 5 SIM card.
  1. Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off. Insert a SIM card eject tool or a  paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
    • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Push the tool into the hole until you see the card pop out.
  2. Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
終わりに
2 の人々がこのガイドを完成させました。
Kyle Libby
メンバー登録日: 2014年04月07日
1,000 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S7G23
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 22
今までの合計 3,164
