メインコンテンツにスキップ
Nexus 5 Rear Facing Camera Replacement
必要な工具と部品
  1. Nexus 5 Rear Facing Camera Replacement, Back Cover: 手順 1、 3の画像 1 Nexus 5 Rear Facing Camera Replacement, Back Cover: 手順 1、 3の画像 2 Nexus 5 Rear Facing Camera Replacement, Back Cover: 手順 1、 3の画像 3
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
  2. Nexus 5 Rear Facing Camera Replacement, Midframe: 手順 2、 1の画像 1
    • Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
    • Ensure you retain all six of the 4.0mm screws! These hold the midframe securely and closely to the motherboard. The three small snaps on the back cover that attach to the midframe ensure the NFC antenna and wireless charging coil connectors contact securely with the motherboard, and work reliably.
    • To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
  3. Nexus 5 Rear Facing Camera Replacement: 手順 3、 2の画像 1 Nexus 5 Rear Facing Camera Replacement: 手順 3、 2の画像 2
    • Remove the midframe from the phone.
    • Examine the midframe and the back cover and you'll find three very small snap attachment points for the back to the midframe. These ensure that the NFC and wireless charging antenna contacts connect with the corresponding spring connectors on the motherboard. Ensure the snaps are in good condition.
  4. Nexus 5 Rear Facing Camera Replacement, Battery: 手順 4、 2の画像 1 Nexus 5 Rear Facing Camera Replacement, Battery: 手順 4、 2の画像 2
    • Use the flat end of a spudger to disconnect the battery connector.
  5. Nexus 5 Rear Facing Camera Replacement, Rear Facing Camera: 手順 5、 2の画像 1 Nexus 5 Rear Facing Camera Replacement, Rear Facing Camera: 手順 5、 2の画像 2
    • Use the flat end of a spudger to disconnect the rear-facing camera.
    • Although the battery is not pictured in this step, it is not necessary to fully remove it in order to get to the rear-facing camera (Only disconnecting it is necessary).
  6. Nexus 5 Rear Facing Camera Replacement: 手順 6、 1の画像 1
    • Use a spudger to gently pry the rear-facing camera up to dislodge it from the adhesive.
    • There is some adhesive securing the rear-facing camera to bottom and sides of its grey housing.
    • Pull the camera laterally towards its ribbon to reveal the circuit board hiding under the motherboard.
    • Don't pull upwards until you can see the black circuit board of the camera fixture.
    • Once you can see all of the camera fixture, you can pull up and remove it.
終わりに
26 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Chris Willis
メンバー登録日: 10/03/14
1,371 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 13-4, Staggers Fall 2014 USF Tampa, Team 13-4, Staggers Fall 2014人のメンバー
USFT-STAGGERS-F14S13G4
3 メンバー
13のガイドは作成済み
1件のガイドコメント
In case anyone else was confused about the end like I was: you don't have to remove the old adhesive, just leave it and put the replacement directly on top of it. It worked just fine for me!
Tony Fastiggi - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 41
今までの合計 23,790
