メインコンテンツにスキップ
Nexus 5 Loudspeaker Replacement
必要な工具と部品
  1. Nexus 5 Loudspeaker Replacement, Back Cover: 手順 1、 3の画像 1 Nexus 5 Loudspeaker Replacement, Back Cover: 手順 1、 3の画像 2 Nexus 5 Loudspeaker Replacement, Back Cover: 手順 1、 3の画像 3
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
  2. Nexus 5 Loudspeaker Replacement, Loudspeaker: 手順 2、 2の画像 1 Nexus 5 Loudspeaker Replacement, Loudspeaker: 手順 2、 2の画像 2
    • Remove the four Phillips #00 screws that secure the speaker assembly.
    • Use a plastic opening tool to gently pry the speaker assembly out of the phone.
終わりに
18 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Chris Willis
メンバー登録日: 10/03/14
1,371 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 13-4, Staggers Fall 2014 USF Tampa, Team 13-4, Staggers Fall 2014人のメンバー
USFT-STAGGERS-F14S13G4
3 メンバー
13のガイドは作成済み
コメント 1 件
Fantastic! My speaker assembly from iFixit arrived today, and about 20 minutes later I'd just saved myself the $600 dolalrs of buying a new phone. Great site, thanks guys!
Charles Comenos - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 21,932
