メインコンテンツにスキップ
Nexus 5 Antenna Cable Replacement
必要な工具と部品
  1. Nexus 5 Antenna Cable Replacement, Remove the Battery Door: 手順 1、 1の画像 1
    • The battery door of the Nexus 5 is held together with plastic clips.
    • Use the plastic spudger to separate the battery door.
  2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 手順 2、 3の画像 1 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 手順 2、 3の画像 2 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 手順 2、 3の画像 3
    • Using your #00 Philips Screwdriver, remove the six screws holding the midframe in place.
    • Remove the four screws at the bottom of the device holding the speaker assembly in place.
    • The screw on the far right may be covered in adhesive. Use your plastic spudger to remove the adhesive covering the screw.
  3. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: 手順 3、 2の画像 1 Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: 手順 3、 2の画像 2
    • Remove the midframe and speaker assembly.
  4. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 手順 4、 3の画像 1 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 手順 4、 3の画像 2 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 手順 4、 3の画像 3
    • The antenna cables are located on the right and left side of the battery (one is gray, the other is black).
    • Using your plastic spudger, disconnect both ends of the antenna cables.
    • Connect your new antenna cables.
    • Make sure the antenna cables are securely connected.
  5. Nexus 5 Antenna Cable Replacement, Reassemble the Device: 手順 5、 2の画像 1 Nexus 5 Antenna Cable Replacement, Reassemble the Device: 手順 5、 2の画像 2
    • Screw the midframe and speaker assembly back into place.
    • Push the outer edges of the battery door down until you hear the plastic clips "click."
    • Hold the power button until you feel the phone vibrate and/or see the Google logo displayed.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Tyler Caldwell
メンバー登録日: 12/07/17
184 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G1, Baechle Fall 2017 IUPUI, Team S1-G1, Baechle Fall 2017人のメンバー
IUPUI-BAECHLE-F17S1G1
2 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 3,029
