メインコンテンツにスキップ
Nexus 4 Camera Replacement
必要な工具と部品
  1. Nexus 4 Camera Replacement, Back Cover: 手順 1、 2の画像 1 Nexus 4 Camera Replacement, Back Cover: 手順 1、 2の画像 2
    この手順で使用する道具:
    SIM Card Eject Tool
    $2.99
    購入する
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Camera Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    T5 Torx Screwdriver
    $5.49
    購入する
  3. Nexus 4 Camera Replacement: 手順 3、 3の画像 1 Nexus 4 Camera Replacement: 手順 3、 3の画像 2 Nexus 4 Camera Replacement: 手順 3、 3の画像 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Camera Replacement, Battery: 手順 4、 2の画像 1 Nexus 4 Camera Replacement, Battery: 手順 4、 2の画像 2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
  5. Nexus 4 Camera Replacement, Battery removal: 手順 5、 2の画像 1 Nexus 4 Camera Replacement, Battery removal: 手順 5、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  6. Nexus 4 Camera Replacement, Plastic Midframe: 手順 6、 3の画像 1 Nexus 4 Camera Replacement, Plastic Midframe: 手順 6、 3の画像 2 Nexus 4 Camera Replacement, Plastic Midframe: 手順 6、 3の画像 3
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
  7. Nexus 4 Camera Replacement, Camera: 手順 7、 3の画像 1 Nexus 4 Camera Replacement, Camera: 手順 7、 3の画像 2 Nexus 4 Camera Replacement, Camera: 手順 7、 3の画像 3
    • Gently pry the metal tab up using a spudger, and lift up the disconnected black flap.
  8. Nexus 4 Camera Replacement: 手順 8、 3の画像 1 Nexus 4 Camera Replacement: 手順 8、 3の画像 2 Nexus 4 Camera Replacement: 手順 8、 3の画像 3
    • With a spudger, carefully pry up the black tab connecting the camera to the motherboard.
    • Lift up the camera from the socket.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Kaitlyn Jones
メンバー登録日: 01/27/13
4,952 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013人のメンバー
CPSU-AMIDO-W13S3G32
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 16
今までの合計 7,880
