メインコンテンツにスキップ
Nexus 4 Back Cover Replacement
必要な工具と部品
  1. Nexus 4 Back Cover Replacement, Back Cover: 手順 1、 2の画像 1 Nexus 4 Back Cover Replacement, Back Cover: 手順 1、 2の画像 2
    この手順で使用する道具:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Back Cover Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    T5 Torx Screwdriver
    $5.49
  3. Nexus 4 Back Cover Replacement: 手順 3、 3の画像 1 Nexus 4 Back Cover Replacement: 手順 3、 3の画像 2 Nexus 4 Back Cover Replacement: 手順 3、 3の画像 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
終わりに
48 の人々がこのガイドを完成させました。
作成者
14人の作成者と共同で作成されました。
Kaitlyn Jones
メンバー登録日: 01/27/13
4,964 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013人のメンバー
CPSU-AMIDO-W13S3G32
4 メンバー
8のガイドは作成済み
3件のガイドコメント
I have made some rearrangement at this guide:
It more logic to remove the tray before removing the screws.
I have used some pictures from the teardown to clarify, particularly for showing the inside of the Nexus 4 showing the battery installed. The original picture did not show the battery. I have also made better reference to the tools.
Gaetan - 返信
I ordered the back case using the provided link at etradesupply.com, and noticed it is not an original part: the wireless charging does not work at all (the coil has a much higher resistance than the original one). After insisting, they sent me another one, which gave the same result. Better avoid buying there if you expect original working products...
Doc Z - 返信
What about the buttons and the NFC? I can buy a back cover with NFC included, but most seem to not have the buttons. Is it easy to remove the ones from the old cover and install them in the new cover?
Martin Fei - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 80
今までの合計 41,314
