メインコンテンツにスキップ
Nexus 10 USB Port Replacement
必要な工具と部品
  1. Nexus 10 USB Port Replacement, Battery: 手順 1、 3の画像 1 Nexus 10 USB Port Replacement, Battery: 手順 1、 3の画像 2 Nexus 10 USB Port Replacement, Battery: 手順 1、 3の画像 3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 USB Port Replacement: 手順 2、 1の画像 1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 USB Port Replacement: 手順 3、 3の画像 1 Nexus 10 USB Port Replacement: 手順 3、 3の画像 2 Nexus 10 USB Port Replacement: 手順 3、 3の画像 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
    Be carefull with the power button cable. Don’t insert the plastic tool in this zone
    Jesus Garcia - 返信
    Some instruction guides also suggest optional use of a suction cup with which to tug on the glass while separating the plastic backing. I found this helpful. Also, if you have a spudger of more rigid plastic, use that one here. My blue spudgers got chewed up pretty badly during this process.
    Jim - 返信
    I found that the top right (looking at the screen) doesn’t have any corner clips, just a metal antenna (?), so it is easiest to get this corner popped first and then work your way around. The bottom corners have clips which are tough to undo.
    Jeremy R - 返信
  4. Nexus 10 USB Port Replacement: 手順 4、 3の画像 1 Nexus 10 USB Port Replacement: 手順 4、 3の画像 2 Nexus 10 USB Port Replacement: 手順 4、 3の画像 3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
    The left two connectors flip up from the cable side. The right connector flips up from opposite the cable.
    Glenn Davis - 返信
    Note that you don’t just pull the ribbons out. There is a clamp on each connector that needs to be prised opened, releasing the ribbon. This was helpful: https://youtu.be/yru4k62qdEU?t=302
    Royston Shufflebotham - 返信
    You sir, are a true humanitarian!!!
    Harold Gue - 返信
  5. Nexus 10 USB Port Replacement: 手順 5、 1の画像 1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 USB Port Replacement: 手順 6、 2の画像 1 Nexus 10 USB Port Replacement: 手順 6、 2の画像 2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
    When reassembling reconnect the data ribbon cables first, then connect the battery connection last so that you’re not plugging in data lines while powered. Ideally you’d disconnect the battery first but that’s a bit hard with the design so you just have to try to ensure it’s switched off first.
    Andrew Whalan - 返信
    Excellent with video
    Jim Scott - 返信
  7. Nexus 10 USB Port Replacement, Headphone Jack: 手順 7、 1の画像 1
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 USB Port Replacement: 手順 8、 3の画像 1 Nexus 10 USB Port Replacement: 手順 8、 3の画像 2 Nexus 10 USB Port Replacement: 手順 8、 3の画像 3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 USB Port Replacement: 手順 9、 3の画像 1 Nexus 10 USB Port Replacement: 手順 9、 3の画像 2 Nexus 10 USB Port Replacement: 手順 9、 3の画像 3
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 USB Port Replacement: 手順 10、 2の画像 1 Nexus 10 USB Port Replacement: 手順 10、 2の画像 2
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 USB Port Replacement: 手順 11、 1の画像 1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 USB Port Replacement: 手順 12、 2の画像 1 Nexus 10 USB Port Replacement: 手順 12、 2の画像 2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
    Expect some resistance when prying up on the vibration motor. There was some aggressive double sided tape under it and it was stuck pretty firmly.
    Jim - 返信
  13. Nexus 10 USB Port Replacement: 手順 13、 2の画像 1 Nexus 10 USB Port Replacement: 手順 13、 2の画像 2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 USB Port Replacement: 手順 14、 2の画像 1 Nexus 10 USB Port Replacement: 手順 14、 2の画像 2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Benjamin Troller
メンバー登録日: 04/11/16
2,181 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S34G18
4 メンバー
5のガイドは作成済み
コメント 1 件
Perfect guide, I managed to fix my Nexus 10 broken usb port.
It may be worth to mention after step 14 you need to gently remove the plastic connectors cover and place it on the replacement part.
Mauri - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 5,584
