メインコンテンツにスキップ
Nexus 10 Headphone Jack Replacement
必要な工具と部品
  1. Nexus 10 Headphone Jack Replacement, Battery: 手順 1、 3の画像 1 Nexus 10 Headphone Jack Replacement, Battery: 手順 1、 3の画像 2 Nexus 10 Headphone Jack Replacement, Battery: 手順 1、 3の画像 3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Headphone Jack Replacement: 手順 2、 1の画像 1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Headphone Jack Replacement: 手順 3、 3の画像 1 Nexus 10 Headphone Jack Replacement: 手順 3、 3の画像 2 Nexus 10 Headphone Jack Replacement: 手順 3、 3の画像 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Headphone Jack Replacement: 手順 4、 3の画像 1 Nexus 10 Headphone Jack Replacement: 手順 4、 3の画像 2 Nexus 10 Headphone Jack Replacement: 手順 4、 3の画像 3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Headphone Jack Replacement: 手順 5、 1の画像 1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Headphone Jack Replacement: 手順 6、 2の画像 1 Nexus 10 Headphone Jack Replacement: 手順 6、 2の画像 2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 Headphone Jack Replacement, Headphone Jack: 手順 7、 1の画像 1
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Headphone Jack Replacement: 手順 8、 3の画像 1 Nexus 10 Headphone Jack Replacement: 手順 8、 3の画像 2 Nexus 10 Headphone Jack Replacement: 手順 8、 3の画像 3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Headphone Jack Replacement: 手順 9、 3の画像 1 Nexus 10 Headphone Jack Replacement: 手順 9、 3の画像 2 Nexus 10 Headphone Jack Replacement: 手順 9、 3の画像 3
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Headphone Jack Replacement: 手順 10、 2の画像 1 Nexus 10 Headphone Jack Replacement: 手順 10、 2の画像 2
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Headphone Jack Replacement: 手順 11、 1の画像 1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Headphone Jack Replacement: 手順 12、 2の画像 1 Nexus 10 Headphone Jack Replacement: 手順 12、 2の画像 2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 Headphone Jack Replacement: 手順 13、 2の画像 1 Nexus 10 Headphone Jack Replacement: 手順 13、 2の画像 2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Headphone Jack Replacement: 手順 14、 2の画像 1 Nexus 10 Headphone Jack Replacement: 手順 14、 2の画像 2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
終わりに
作成者
6人の作成者と共同で作成されました。
Benjamin Troller
メンバー登録日: 04/11/16
2,181 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S34G18
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 18
今までの合計 736
