はじめに
Replace a dead or failing battery in your Nexus 10 by completing the following guide. The battery should also be removed as a safety precaution before performing any other repairs on this device.
必要な工具と部品
Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
63 の人々がこのガイドを完成させました。
20 件のコメント
that worked! watch connectors,though!
Dan Hestad - 返信
I am not never before doing something like this before, but now i do this battery replacement and it worked very well. Maybe there could be more text describing steps 4 and 6 those were parts were me as complete novice had most difficult to understand at first. Step 4 you should say that you need to open that small lever-thing what locks ribboncables in its place (picture here is accurate, but i did not understand it at first). And step 6 disconnecting actual battery cable were more simple than i first thought, just lifting it upwards and then its basically free already just pull it away. Same connecting new battery cable back is same kind simple, just push it back there but better to do it first time right since that connector loosens easily i think.
The back cover is one tough motherFer. The hardest is get to the pins behind the both speakers and in the curved corners. But the overall design is so cool
