メインコンテンツにスキップ
Nextbook 8 Screen Replacement
必要な工具と部品
  1. Nextbook 8 Screen Replacement, Battery: 手順 1、 2の画像 1 Nextbook 8 Screen Replacement, Battery: 手順 1、 2の画像 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Screen Replacement: 手順 2、 2の画像 1 Nextbook 8 Screen Replacement: 手順 2、 2の画像 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Screen Replacement: 手順 3、 2の画像 1 Nextbook 8 Screen Replacement: 手順 3、 2の画像 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Screen Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Screen Replacement: 手順 5、 2の画像 1 Nextbook 8 Screen Replacement: 手順 5、 2の画像 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
  6. Nextbook 8 Screen Replacement, Screen: 手順 6、 1の画像 1
    • Remove the silver and gold sticker at the bottom of the device.
    • Hold the brown circuit board down with your finger while you remove the sticker
  7. Nextbook 8 Screen Replacement: 手順 7、 2の画像 1 Nextbook 8 Screen Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a spudger to lift up the black tabs on the three ZIF connectors.
    • Use ESD safe tweezers to pull the ribbon cables out of the three connectors.
  8. Nextbook 8 Screen Replacement: 手順 8、 2の画像 1 Nextbook 8 Screen Replacement: 手順 8、 2の画像 2
    • Remove the 5 black screws on the motherboard.
    • Carefully lift the motherboard off of the device and remove.
  9. Nextbook 8 Screen Replacement: 手順 9、 2の画像 1 Nextbook 8 Screen Replacement: 手順 9、 2の画像 2
    • Remove the two screws that hold the brackets in place.
    • Remove the two silver brackets that hold the screen in place.
  10. Nextbook 8 Screen Replacement: 手順 10、 2の画像 1 Nextbook 8 Screen Replacement: 手順 10、 2の画像 2
    • Remove the one silver screw on the small green circuit board at the bottom of the device.
    • Set aside the small circuit board for now.
  11. Nextbook 8 Screen Replacement: 手順 11、 1の画像 1
    • Remove the two silver screws from the bottom of the device.
  12. Nextbook 8 Screen Replacement: 手順 12、 3の画像 1 Nextbook 8 Screen Replacement: 手順 12、 3の画像 2 Nextbook 8 Screen Replacement: 手順 12、 3の画像 3
    • With the device face down, use a spudger to lift the screen off of the glass from the right side.
終わりに
21 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Dylan Wiese
メンバー登録日: 03/11/15
1,853 ポイント
5のガイドは作成済み
チーム
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S5G1
3 メンバー
10のガイドは作成済み
コメント 1 件
where do I find the actual screen though
WiKiT Woo WoNKa - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 23,895
