はじめに
This guide will cover how to replace the solenoid PCB if it no longer operates as intended. Be sure to handle with care when unplugging cables and wires as to prevent any further damage and new replacements. There are some extra helpful tips that can be found in the user manual on page 67.
必要な工具と部品
Place device so that the top cover is facing you.
Open the top cover.
Pull up and remove the flexible rubber exhalation outlet boot (push fit).
Remove the 2 screws and washers securing the manifold/mixer assembly
Remove the screw and washer that secure the exhalation manifold support to the pneumatic panel.
Remove the cable from the connector J1 on the analog PCB.
Carefully pull the tubes from their connections opposite the solenoid PCB (not directly from the solenoid PCB). Make note of the tubing connections for re-assembly.
