メインコンテンツにスキップ
Newport e500 Pneumatic Box Disassembly
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
必要な工具と部品
  1. Newport e500 Pneumatic Box Disassembly, Newport e500 Top Cover Disassembly: 手順 1、 1の画像 1
    • Place device so that the top cover is facing you.
    • Open the top cover.
  2. Newport e500 Pneumatic Box Disassembly: 手順 2、 1の画像 1
    • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
  3. Newport e500 Pneumatic Box Disassembly: 手順 3、 1の画像 1
    • Remove the cover and set aside. Retain hardware for re-assembly.
  4. Newport e500 Pneumatic Box Disassembly, Newport e500 Left Side Panel Disassembly: 手順 4、 1の画像 1
    • Carefully place the GDU on its right side with the front of the GDU facing you.
    • Remove the three screws and washers at the top edge of the left side panel.
  5. Newport e500 Pneumatic Box Disassembly: 手順 5、 1の画像 1
    • Remove the two screws and washers from the underside of the left side panel.
  6. Newport e500 Pneumatic Box Disassembly: 手順 6、 1の画像 1
    • Remove the left side panel. Retain hardware for re-assembly.
  7. Newport e500 Pneumatic Box Disassembly, Newport e500 Right Side Panel Disassembly: 手順 7、 1の画像 1
    • Carefully place the GDU on its left side.
  8. Newport e500 Pneumatic Box Disassembly: 手順 8、 1の画像 1
    • Remove the four screws and washers at the top edge of the right side panel.
  9. Newport e500 Pneumatic Box Disassembly: 手順 9、 1の画像 1
    • Remove the two screws and washers from the underside of the right side panel.
  10. Newport e500 Pneumatic Box Disassembly: 手順 10、 1の画像 1
    • Remove the right side panel. Retain hardware for re-assembly.
  11. Newport e500 Pneumatic Box Disassembly, Newport e500 Flow Sensor Cover Disassembly: 手順 11、 1の画像 1
    • Remove the three screws and washers that secure the flow sensor cover to the pneumatic box assembly. Retain the hardware for re-assembly.
  12. Newport e500 Pneumatic Box Disassembly: 手順 12、 1の画像 1
    • Remove the flow sensor cover.
  13. Newport e500 Pneumatic Box Disassembly, Newport e500 Exhalation Module Disassembly: 手順 13、 1の画像 1
    • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
  14. Newport e500 Pneumatic Box Disassembly: 手順 14、 1の画像 1
    • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
  15. Newport e500 Pneumatic Box Disassembly: 手順 15、 1の画像 1
    • Pull the exhalation module straight up to remove it from the GDU.
  16. Newport e500 Pneumatic Box Disassembly, Newport e500 Pneumatic Box Disassembly: 手順 16、 1の画像 1
    • Remove the two screws and washers (back corners), one screw and washer (exhalation module support bracket), and two standoffs and washers (front corners) that secure the pneumatic (upper) box assembly to the electronic box assembly. Lift the Pneumatics Box and carefully tilt to one side.
  17. Newport e500 Pneumatic Box Disassembly: 手順 17、 1の画像 1
    • Remove cables from connectors J1, J2, J3, J4, J5, and J6 on the main PCB (4 connectors are not shown due to being blocked by the side panel). Note the position of these connectors for re-assembly.
  18. Newport e500 Pneumatic Box Disassembly: 手順 18、 1の画像 1
    • If not already detached, remove the heater cables from J5 and J6 on the DC-DC power supply PCB.
終わりに
作成者
1人の作成者と共同作成されました。
Jared McMullen
メンバー登録日: 05/02/18
473 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S7-G16, Paton Spring 2020 Cal Poly, Team S7-G16, Paton Spring 2020人のメンバー
CPSU-PATON-S20S7G16
3 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 87
