メインコンテンツにスキップ
New Speed 26-inch Electric Bike Throttle Replacement
必要な工具と部品
  1. New Speed 26-inch Electric Bike Throttle Replacement, Electric Bike Throttle: 手順 1、 1の画像 1
    • Remove the 3/32" Allen screw from the top of the throttle.
    • When removing the screw, make sure the wrench is well seated to avoid damaging the screw.
    • Make sure that your bike's power is turned off before beginning to disassemble it.
  2. New Speed 26-inch Electric Bike Throttle Replacement: 手順 2、 1の画像 1
    • Remove the 5/64" Allen screw from the underside of the throttle.
  3. New Speed 26-inch Electric Bike Throttle Replacement: 手順 3、 1の画像 1
    • Slide the throttle off of the handlebar.
    • Be careful when removing the throttle. Taking it off too quickly could result in damage to the wiring.
  4. New Speed 26-inch Electric Bike Throttle Replacement: 手順 4、 1の画像 1
    • Remove the two 2mm Phillips screws from the back of the control box.
    • Repeat this process for the other side of the control box. 4 screws will be removed in total.
  5. New Speed 26-inch Electric Bike Throttle Replacement: 手順 5、 1の画像 1
    • Open the control box.
  6. New Speed 26-inch Electric Bike Throttle Replacement: 手順 6、 2の画像 1 New Speed 26-inch Electric Bike Throttle Replacement: 手順 6、 2の画像 2
    • Unwrap the cable lining surrounding the throttle cable.
    • Track the throttle cable to the control box.
    • Disconnect the JST-SM connector from the main controller.
    • Take caution while handling these wires. They can be easily damaged.
  7. New Speed 26-inch Electric Bike Throttle Replacement: 手順 7、 2の画像 1 New Speed 26-inch Electric Bike Throttle Replacement: 手順 7、 2の画像 2
    • Cut the zip ties found along the frame of the bike.
    • Remove the throttle and its wires from the frame of the bike.
    • Be careful not to cut too close to the wires, as you could risk damaging them or hurting yourself.
終わりに
To reassemble your device, follow the steps in reverse order.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Ryan Arnold
メンバー登録日: 10/06/22
176 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 2-1, Raign Fall 2022 University of North Texas, Team 2-1, Raign Fall 2022人のメンバー
UNT-RAIGN-F22S2G1
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 48
今までの合計 810
