この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will help you to take apart your Netgear ProSAFE GS105 Gigabit Switch. Use this guide as a starting point to get into the switch before doing routine maintinence.
必要な工具と部品
Remove the two 4.04 mm Phillips Head screws with a PH1 bit or Phillips #1 Screwdriver and set screws aside.
Use gentle pressure to pull back the top and rear panel of the switch away from the body and set side.
Use your PH2 bit or a Phillips #2 Screwdriver to remove the 6.94mm Phillips Head screws that hold the board into the bottom of the case.
CAUTION: The screws have two washers on each screw, make use you keep these with the screws.
Use light pressure to lift the board from the screw standoffs and gently pull backwards to remove the board from the case.
When reassembling the device make sure you correctly line up the RJ45 ports with the front of the case and the board is properly sittingon the screw standoffs before reinserrting the screws.
The board has now been removed from the casing and is ready for maintinence or repair.
In ordertjhe put the device back togeather follow the steps outlined in reverse.
You are now finished!
コメント 1 件
is there some associated repair guide (like for one that won't power up), or only this Disassembly Guide? (if only the latter, then why bother?). While not worth repairing for any cost savings (they can be had for $15 second hand), they would be good devices for practicing repair skills like diagnosing and replacing board components, with little risk.
