メインコンテンツにスキップ
Nest Learning Thermostat 2nd Generation Battery Replacement
必要な工具と部品
  1. Nest Learning Thermostat 2nd Generation Battery Replacement, Removal from Wall: 手順 1、 2の画像 1 Nest Learning Thermostat 2nd Generation Battery Replacement, Removal from Wall: 手順 1、 2の画像 2
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation Battery Replacement, Open Display: 手順 2、 1の画像 1
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove the back of the display: 手順 3、 2の画像 1 Nest Learning Thermostat 2nd Generation Battery Replacement, Remove the back of the display: 手順 3、 2の画像 2
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: 手順 4、 3の画像 1 Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: 手順 4、 3の画像 2 Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the base connection ribbon cable.: 手順 4、 3の画像 3
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation Battery Replacement, Lift battery from the base: 手順 5、 2の画像 1 Nest Learning Thermostat 2nd Generation Battery Replacement, Lift battery from the base: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the battery from the motherboard: 手順 6、 2の画像 1 Nest Learning Thermostat 2nd Generation Battery Replacement, Disconnect the battery from the motherboard: 手順 6、 2の画像 2
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: 手順 7、 3の画像 1 Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: 手順 7、 3の画像 2 Nest Learning Thermostat 2nd Generation Battery Replacement, Remove battery from the display: 手順 7、 3の画像 3
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
終わりに
44 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Dustinluckenbill
メンバー登録日: 09/23/14
703 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S11G5
5 メンバー
12のガイドは作成済み
15件のガイドコメント
It should be noted that doing this will void the warranty on your device. If you are having issues with the display battery you should call the tech support line and they will help you. Doing this risk damaging the device and making it to where they will not replace it if it is still under warranty.
Bob bobbado - 返信
ON MY NEST WHEN YOU "pull 2"...IT WAS GLUED TO THE METAL TOP OP THE MOTHERBOARD UNDERNEATH...SO IF THIS IS THE CASE BE VERY CAREFUL AS YOU DISLODGE THE BATTERY ....ALSO THE PLUG FOR THE BATTERY WAS TAPED DOWN WITH AMBER COLORED TAPE WHICH I HAD TO REMOVE BEFORE I WAS ABLE TO UNPLUG THE BATTERY...I REPLACED THE TAPE WITH SOME SCOTCH TAPE AFTER REINSTALLING THE BATTERY...ALL IN ALL...GOO INSTRUCTIONS...A FIVE MINUTE FIX !!!
Andrew Jordan - 返信
I also am having a time finding the replacement battery
Brian wilson -
I am having trouble locating a replacement battery. Any idea where to look?
Ron Temaat - 返信
As of 12/28/17 this website has replacement batteries for $12 plus shipping:
www.batteryclerk.com
Here’s a direct link to the Gen1 battery page which has a link to the Gen2 battery page
http://www.batteryclerk.com/products/nes...
Ron Saritzky - 返信
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 157
過去 30 日: 720
今までの合計 178,163
