メインコンテンツにスキップ
Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement
必要な工具と部品
  1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: 手順 1、 2の画像 1 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: 手順 1、 2の画像 2
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Open Display: 手順 2、 1の画像 1
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: 手順 3、 2の画像 1 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: 手順 3、 2の画像 2
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: 手順 4、 3の画像 1 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: 手順 4、 3の画像 2 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: 手順 4、 3の画像 3
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: 手順 5、 2の画像 1 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: 手順 5、 2の画像 2
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: 手順 6、 2の画像 1 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: 手順 6、 2の画像 2
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: 手順 7、 3の画像 1 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: 手順 7、 3の画像 2 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: 手順 7、 3の画像 3
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
  8. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Locate auto-away sensor: 手順 8、 1の画像 1
    • Locate the auto-away sensor.
  9. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: 手順 9、 2の画像 1 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: 手順 9、 2の画像 2
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
  10. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: 手順 10、 3の画像 1 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: 手順 10、 3の画像 2 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: 手順 10、 3の画像 3
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Justin Curry
メンバー登録日: 09/23/14
258 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S11G5
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,977
