はじめに
This guide will help you replace a leaky O-Ring caused by exposure to the elements or damage during disassembly. All you will need to access this are iFixit opening picks. It is recommended that this is replaced anytime the device is opened as it can be pinched or torn during removal of the face plate or device housing.
必要な工具と部品
Insert the pick between the black faceplate and white casing of the Nest Hello.
Pry the faceplate away from the device with the opening pick.
Completely remove the faceplate from the device, do not be afraid to pull hard.
Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
3 の人々がこのガイドを完成させました。
2 件のコメント
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
