メインコンテンツにスキップ
Nest Hello Microphone Replacement
必要な工具と部品
  1. Nest Hello Microphone Replacement, Casing and Faceplate: 手順 1、 1の画像 1
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello Microphone Replacement: 手順 2、 2の画像 1 Nest Hello Microphone Replacement: 手順 2、 2の画像 2
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello Microphone Replacement: 手順 3、 3の画像 1 Nest Hello Microphone Replacement: 手順 3、 3の画像 2 Nest Hello Microphone Replacement: 手順 3、 3の画像 3
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello Microphone Replacement, Motherboard: 手順 4、 1の画像 1
    • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
  5. Nest Hello Microphone Replacement: 手順 5、 2の画像 1 Nest Hello Microphone Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Grip the connector with the tweezers as shown and pull it away from the casing.
  6. Nest Hello Microphone Replacement: 手順 6、 1の画像 1
    • Remove the six smaller screws shown with the Phillips #000 screwdriver.
    • Remove the three larger screws shown with the Phillips #000 screwdriver.
  7. Nest Hello Microphone Replacement: 手順 7、 2の画像 1 Nest Hello Microphone Replacement: 手順 7、 2の画像 2
    • Holding the device as shown push the circuit board away from you and up to free it from the clips.
  8. Nest Hello Microphone Replacement: 手順 8、 2の画像 1 Nest Hello Microphone Replacement: 手順 8、 2の画像 2
    • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
  9. Nest Hello Microphone Replacement: 手順 9、 1の画像 1
    • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
    • Work your way around the device, prying the circuit board away from the housing.
    • Make sure to feed the wires when taking off the circuit board.
    • The microphone on this device is integrated into the black plastic housing removed in the previous step. This entire piece must be replaced rather than the microphone individually.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Daniel Moore
メンバー登録日: 01/14/20
902 ポイント
6のガイドは作成済み
1件のガイドコメント
Where did you get the microphone replacement part?
Pedro Cruz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 21
今までの合計 1,556
