メインコンテンツにスキップ
Nest Hello Casing and Faceplate Replacement
必要な工具と部品
  1. Nest Hello Casing and Faceplate Replacement, Casing and Faceplate: 手順 1、 1の画像 1
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello Casing and Faceplate Replacement: 手順 2、 2の画像 1 Nest Hello Casing and Faceplate Replacement: 手順 2、 2の画像 2
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello Casing and Faceplate Replacement: 手順 3、 3の画像 1 Nest Hello Casing and Faceplate Replacement: 手順 3、 3の画像 2 Nest Hello Casing and Faceplate Replacement: 手順 3、 3の画像 3
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
終わりに
作成者
3人の作成者と共同で作成されました。
Daniel Moore
メンバー登録日: 01/14/20
902 ポイント
6のガイドは作成済み
2件のガイドコメント
Are Replacement parts available anywhere? Can’t seem to find anything… thanks!
Andres Chavez - 返信
Aside from fine grit sanding and spray painting or using a silicone cover, has anyone found a creative way to fix the delaminated an existing Gen 1 Google Nest wired / Nest Hello doorbell faceplate (remove the rest of the flaking off laminate)?
RickSoFlo - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 74
今までの合計 3,209
