はじめに
This guide is needed to replace the mounting clips if they do not securely hold the camera in its mount. Make sure the device is unplugged before opening.
必要な工具と部品
Press in the mounting clips on each side of the case to remove the camera from the mount.
Using a Philips #0 screwdriver, remove the four 4 mm screws that are attaching the mounting clips to the case.
終わりに
