メインコンテンツにスキップ
Nest Dropcam Pro Micro-USB Port Replacement
必要な工具と部品
  1. Nest Dropcam Pro Micro-USB Port Replacement, Outer Case: 手順 1、 1の画像 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Micro-USB Port Replacement: 手順 2、 2の画像 1 Nest Dropcam Pro Micro-USB Port Replacement: 手順 2、 2の画像 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Micro-USB Port Replacement: 手順 3、 2の画像 1 Nest Dropcam Pro Micro-USB Port Replacement: 手順 3、 2の画像 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: 手順 4、 2の画像 1 Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: 手順 4、 2の画像 2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Micro-USB Port Replacement: 手順 5、 2の画像 1 Nest Dropcam Pro Micro-USB Port Replacement: 手順 5、 2の画像 2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Micro-USB Port Replacement: 手順 6、 2の画像 1 Nest Dropcam Pro Micro-USB Port Replacement: 手順 6、 2の画像 2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Micro-USB Port Replacement: 手順 7、 2の画像 1 Nest Dropcam Pro Micro-USB Port Replacement: 手順 7、 2の画像 2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: 手順 8、 2の画像 1 Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: 手順 8、 2の画像 2
    • Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
    • Lift the Micro-USB port away from the motherboard.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
David Foens
メンバー登録日: 09/03/15
893 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S15G4
3 メンバー
12のガイドは作成済み
4 件のコメント
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Kreschendalyn Backus - 返信
Did it work for you?
Michael Candy -
Where can you order the micro-usb charge port for this cam?
Danny Acevedo - 返信
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
https://bit.ly/2Kg01z6
Debbie - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 30
今までの合計 5,825
