メインコンテンツにスキップ
Nest Cam Mic Cable Replacement
必要な工具と部品
  1. Nest Cam Mic Cable Replacement, Mic Cable: 手順 1、 1の画像 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Mic Cable Replacement: 手順 2、 3の画像 1 Nest Cam Mic Cable Replacement: 手順 2、 3の画像 2 Nest Cam Mic Cable Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    購入する
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Mic Cable Replacement: 手順 3、 1の画像 1
    • Holding the back panel firmly, use a spudger to pry off the small plastic panel holding the mic cable in place.
    • Use a heat gun to melt the glue keeping the mic cable in place and then remove it.
    • During reassembly this plastic piece may need to be glued back on to ensure the mic cable stays in place on the back panel.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jade Weiss
メンバー登録日: 02/24/16
662 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016人のメンバー
USFT-LEAHY-S16S1G1
7 メンバー
10のガイドは作成済み
3 件のコメント
Thank you for this look inside the device. In the Nest settings there is a way to turn off the microphone, but anyone with access can turn it back on. I'm going to use this guide to unplug the microphone and permanently (but reversibly) disable it.
Bruce MacDonald - 返信
Yes, by accessing the settings either via the app, or the website. Device options will all you to control the mic recording, or notifications if you just don't want to know when it picks up audio. Each app has its own settings on my devices, I think, but don't quote me on that one.
Be He - 返信
Good job.
Do you have any idea if the cam doesn't restart?
Thanks.
Summer
summer - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 25
今までの合計 3,748
