はじめに
The Nest Cam also has a listening function. The mic cable is responsible for sound intake. If your Nest Cam's sound is either not transmitting or muffled or even indistinguishable, the mic cable may need to be replaced.
必要な工具と部品
Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
ある他の人がこのガイドを完成しました。
3 件のコメント
Thank you for this look inside the device. In the Nest settings there is a way to turn off the microphone, but anyone with access can turn it back on. I'm going to use this guide to unplug the microphone and permanently (but reversibly) disable it.
