はじめに
There are some instances when the spring which allows a person to fire a Nerf crossbow breaks. One you have opened up the Nerf crossbow you will be able to tell whether or not the spring has broken. If in fact you are dealing with a broken swing then you are in luck since it can be replaced.
必要な工具と部品
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
