はじめに
A damaged safety lever can be replaced by disassembling the gun with a screwdriver.
必要な工具と部品
Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
Remove the twelve #00 1 cm Phillips screws.
Rotate the gun so that the front is facing you to remove the final screw.
Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
Remove the #00 1.2 cm Phillips screw located to the right of the white casing.
Wiggle the front cover out from under the white piece and lift up from the gun.
Disconnect the inner mechanism from the outer cover by lifting the inner mechanism towards you.
Rotate the gun so that the top is facing you.
Remove the two #00 1 cm Phillips screws holding the white safety cover in place. Lift off the safety cover.
Pull the lever up on one side with some force until the knobs on the side of the lever pop out of the grooves.
ある他の人がこのガイドを完成しました。
