メインコンテンツにスキップ
Nerf Vortex Vigilon Clip Attachment Replacement
必要な工具と部品
  1. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the slide screws: 手順 1、 1の画像 1
    • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
    • Both sides of the slide will come off when the screws are removed.
  2. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the slide pieces: 手順 2、 1の画像 1
    • Lift both slide pieces off of the gun.
  3. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outer screws: 手順 3、 2の画像 1 Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outer screws: 手順 3、 2の画像 2
    • Remove the twelve #00 1 cm Phillips screws.
    • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
    • Rotate the gun so that the front is facing you to remove the final screw.
  4. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outside cover: 手順 4、 1の画像 1
    • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
    • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
    • The magazine will slide down automatically as you remove the cover.
  5. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the clip attachment: 手順 5、 2の画像 1 Nerf Vortex Vigilon Clip Attachment Replacement, Removing the clip attachment: 手順 5、 2の画像 2
    • At the top left area of the gun, lift the clip towards you, and it will easily slide out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Cara Pew
メンバー登録日: 09/29/14
911 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 13-6, Forte Fall 2014 Cal Poly, Team 13-6, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S13G6
5 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,157
