はじめに
If any part of the trigger assembly breaks, this guide will show how to remove any problematic areas. A screwdriver with a long shaft will be needed to get to all of the screws. Also watch out for any small parts that may come apart and fall out as you're working on the device.
必要な工具と部品
Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3-cm screws in the pump.
ある他の人がこのガイドを完成しました。
