はじめに
The internal loading mechanism can undergo a lot of stress during operation and can break as a result. Replacing the assembly is a much easier and efficient fix than any individual part. A screwdriver with a long shaft will be needed to get to all of the screws. Also watch out for any small parts that may come apart and fall out as you're working on the device.
必要な工具と部品
Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3 cm screws in the pump.
もう少しです!
終わりに
