メインコンテンツにスキップ
Nerf Recon CS-6 O-Ring Replacement
必要な工具と部品
  1. Nerf Recon CS-6 O-Ring Replacement, Remove Magazine: 手順 1、 1の画像 1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Nerf Recon CS-6 O-Ring Replacement, Remove Visible Screws: 手順 2、 1の画像 1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Nerf Recon CS-6 O-Ring Replacement, Remove Hidden Screws: 手順 3、 2の画像 1 Nerf Recon CS-6 O-Ring Replacement, Remove Hidden Screws: 手順 3、 2の画像 2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Nerf Recon CS-6 O-Ring Replacement, Remove Plunger Cap: 手順 4、 1の画像 1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Nerf Recon CS-6 O-Ring Replacement, Remove Slide Screws: 手順 5、 1の画像 1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Nerf Recon CS-6 O-Ring Replacement, Split the Gun in Half: 手順 6、 2の画像 1 Nerf Recon CS-6 O-Ring Replacement, Split the Gun in Half: 手順 6、 2の画像 2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
  7. Nerf Recon CS-6 O-Ring Replacement, Remove Spring: 手順 7、 2の画像 1 Nerf Recon CS-6 O-Ring Replacement, Remove Spring: 手順 7、 2の画像 2
    • Pull the spring out the back of the gun.
  8. Nerf Recon CS-6 O-Ring Replacement, Removing Plunger Guide: 手順 8、 1の画像 1
    • Lift the plunger guide straight up out of the gun.
  9. Nerf Recon CS-6 O-Ring Replacement, Remove Plunger: 手順 9、 1の画像 1
    • Pull the plunger out the back of the gun off of the inner piece.
  10. Nerf Recon CS-6 O-Ring Replacement, Remove  Other Half of Plunger: 手順 10、 1の画像 1
    • Pull the remaining half of the plunger out the back of the gun.
  11. Nerf Recon CS-6 O-Ring Replacement, Removing O-Ring: 手順 11、 1の画像 1
    • Use tweezers to lift the O-Ring out of groove.
    • Replace with new O-Ring.
    • Optional: add a small amount of a lubricant safe for the O-Ring such as petroleum jelly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Pam Ruffner
メンバー登録日: 10/20/14
984 ポイント
3のガイドは作成済み
チーム
Baylor, Team 8-14, Williams Fall 2014 Baylor, Team 8-14, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G14
3 メンバー
6のガイドは作成済み
コメント 1 件
Ace Hardware 1/16x13/16x1/16 #37 R-80 O-Ring fits
Mr.H - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 17
今までの合計 2,413
