はじめに
This guide is going to show you how to take apart the blaster to reach the spring that is located in cocking mechanism of the Nerf.
必要な工具と部品
Remove the screw on the inside of the gun.
Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
17 の人々がこのガイドを完成させました。
21 件のコメント
Where does the locking tab in step 5 go
on the top of the gun(Seeing from the position as if you're aiming)
Its only there for accesory so it still works if you don't return it
chanisco -
