メインコンテンツにスキップ
Nerf N-Strike Elite Retaliator Trigger Spring Replacement
必要な工具と部品
  1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: 手順 1、 1の画像 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 手順 2、 1の画像 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 手順 3、 1の画像 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 手順 4、 2の画像 1 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 手順 4、 2の画像 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 手順 5、 2の画像 1 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 手順 5、 2の画像 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 手順 6、 3の画像 1 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 手順 6、 3の画像 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 手順 6、 3の画像 3
    • Carefully pull the orange trigger upward and backward to remove it from the blaster.
    • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
    • Remove the spring from the rear of the trigger.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
ericharman
メンバー登録日: 03/02/16
1,422 ポイント
5のガイドは作成済み
1 Guide Comment
ok, taken the spring out. now what?
Kelvin Mead - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 40
今までの合計 9,557
