メインコンテンツにスキップ
Nerf N-Strike Elite Retaliator Spring Replacement
必要な工具と部品
  1. Nerf N-Strike Elite Retaliator Spring Replacement, Case Disassembly: 手順 1、 1の画像 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Spring Replacement: 手順 2、 1の画像 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Spring Replacement: 手順 3、 1の画像 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Spring Replacement: 手順 4、 2の画像 1 Nerf N-Strike Elite Retaliator Spring Replacement: 手順 4、 2の画像 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Spring Replacement: 手順 5、 2の画像 1 Nerf N-Strike Elite Retaliator Spring Replacement: 手順 5、 2の画像 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: 手順 6、 2の画像 1 Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: 手順 6、 2の画像 2
    • The spring may be compressed. If so, carefully release spring pressure before proceeding.
    • While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
ericharman
メンバー登録日: 03/02/16
1,410 ポイント
5のガイドは作成済み
2 件のコメント
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
Ryan Zhang - 返信
can i use a nerf kronos spring
jordan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 31
今までの合計 12,665
