メインコンテンツにスキップ
Nerf N-Strike Elite Retaliator Case Disassembly
必要な工具と部品
  1. Nerf N-Strike Elite Retaliator Case Disassembly, Case Disassembly: 手順 1、 1の画像 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Case Disassembly: 手順 2、 1の画像 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Case Disassembly: 手順 3、 1の画像 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Case Disassembly: 手順 4、 2の画像 1 Nerf N-Strike Elite Retaliator Case Disassembly: 手順 4、 2の画像 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Case Disassembly: 手順 5、 2の画像 1 Nerf N-Strike Elite Retaliator Case Disassembly: 手順 5、 2の画像 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
ゴール
28 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
ericharman
メンバー登録日: 03/02/16
1,422 ポイント
5のガイドは作成済み
15件のガイドコメント
How do I clean the slider track?
devinwhaley - 返信
you probably should not do that. i think its oily for a reason.
one smol birb -
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay -
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Pete Isaacs - 返信
Leave the screws in the casing
Ewan Dority -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 116
今までの合計 36,422
