メインコンテンツにスキップ
Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement
必要な工具と部品
  1. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: 手順 1、 3の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: 手順 1、 3の画像 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: 手順 1、 3の画像 3
    • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
    • Remove the two 9.0 mm Phillips screws securing the battery compartment.
    • Slide the battery compartment out.
  2. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 2、 1の画像 1
    • Remove the five 9.0 mm Phillips screws securing the trigger.
  3. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 3、 2の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 3、 2の画像 2
    • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
    • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
  4. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 4、 3の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 4、 3の画像 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 4、 3の画像 3
    • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
    • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
  5. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 5、 1の画像 1
    • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
  6. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 6、 1の画像 1
    • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
  7. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 7、 1の画像 1
    • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
    • Remove the single 7.0 mm Phillips screw below the barrel.
    • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
  8. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 8、 1の画像 1
    • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
  9. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 9、 2の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 9、 2の画像 2
    • Remove the two 9.0 mm Phillips screws holding together the handle.
    • Remove the plastic cover of the handle.
  10. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 10、 2の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 10、 2の画像 2
    • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
    • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
  11. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 11、 3の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 11、 3の画像 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 11、 3の画像 3
    • Pull one end of the handle away from the orange latch.
    • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
  12. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 12、 3の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 12、 3の画像 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 12、 3の画像 3
    • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
    • Completely remove the left shell from the rest of the Nerf Gun.
  13. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: 手順 13、 3の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: 手順 13、 3の画像 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: 手順 13、 3の画像 3
    • Remove the cartridge support.
  14. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 14、 3の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 14、 3の画像 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 14、 3の画像 3
    • Remove the handle crank.
  15. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 15、 2の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 15、 2の画像 2
    • Remove the clear plastic barrel cover.
  16. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 16、 2の画像 1 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: 手順 16、 2の画像 2
    • Remove the firing pin.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
sage
メンバー登録日: 01/24/14
301 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 13-13, Regan Winter 2014 Cal Poly, Team 13-13, Regan Winter 2014人のメンバー
CPSU-REGAN-W14S13G13
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,187
