メインコンテンツにスキップ
Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement
必要な工具と部品
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Notes Before Starting: 手順 1、 1の画像 1
    • There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
    • Be sure that the rifle is discharged and unloaded before starting disassembly.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Rear Cap Removal: 手順 2、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Rear Cap Removal: 手順 2、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Rear Cap Removal: 手順 2、 3の画像 3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Slide Removal: 手順 3、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Slide Removal: 手順 3、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Slide Removal: 手順 3、 3の画像 3
    • With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement: 手順 4、 2の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement: 手順 4、 2の画像 2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement: 手順 5、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement: 手順 5、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement: 手順 5、 3の画像 3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Spring Removal: 手順 6、 1の画像 1
    • You should now be able to pull the main firing spring from the rear of the rifle.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement, Plunger: 手順 7、 1の画像 1
    • Slide the plunger lock rearwards and towards yourself to lift it out.
  8. Nerf N-Strike Elite Alpha Trooper CS-12 Plunger Replacement: 手順 8、 1の画像 1
    • Pull the plunger towards the rear of the rifle to remove it.
終わりに
作成者
4人の作成者と共同で作成されました。
Elizabeth Coffey
メンバー登録日: 01/26/14
404 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-35, Maness Winter 2014 Cal Poly, Team 10-35, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G35
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 4,498
