はじめに
A damaged hammer rod may make it difficult, or entirely prevent the slide from operating. This can make loading the rifle difficult. This guide shows you how to access and replace the silver hammer rod next to the barrel of the Nerf gun.
必要な工具と部品
Be sure that the rifle is discharged and unloaded before starting disassembly.
Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
Pull off the orange cap.
With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
Separate and remove the two halves of the slide mechanism.
You should now be able to pull the main firing spring from the rear of the rifle.
ある他の人がこのガイドを完成しました。
