メインコンテンツにスキップ
Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement
必要な工具と部品
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Notes Before Starting: 手順 1、 1の画像 1
    • There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
    • Be sure that the rifle is discharged and unloaded before starting disassembly.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: 手順 2、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: 手順 2、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: 手順 2、 3の画像 3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: 手順 3、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: 手順 3、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: 手順 3、 3の画像 3
    • With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 4、 2の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 4、 2の画像 2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 5、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 5、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 5、 3の画像 3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Spring Removal: 手順 6、 1の画像 1
    • You should now be able to pull the main firing spring from the rear of the rifle.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Hammer Rod: 手順 7、 2の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Hammer Rod: 手順 7、 2の画像 2
    • Remove the two 5 mm phillips screws holding the muzzle in place.
  8. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 8、 1の画像 1
    • Remove the barrel and muzzle assembly from the gun body.
  9. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 9、 2の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 9、 2の画像 2
    • Remove the 5mm phillips screw holding in the chamber lock mechanism.
  10. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 10、 2の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 10、 2の画像 2
    • Pull the front chamber lock spring up and out of its seat.
    • Pull the front chamber lock mechanism down and out of the rifle barrel.
    • Note there are two pieces to this mechanism.
  11. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 11、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 11、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 11、 3の画像 3
    • Holding the rear chamber slide lock down, slide the chamber to the rear of the rifle.
    • Remove the rear section of the barrel.
  12. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 12、 1の画像 1
    • With the plunger in the air cylinder, pull the plunger lock out of the rifle body.
  13. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 13、 1の画像 1
    • Pull the air cylinder and plunger assembly rearwards and out of the rifle.
  14. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 14、 1の画像 1
    • While holding the slide lock mechanism down, pull the bullet chamber assembly up and out of the rifle.
    • Part of the magazine lock mechanism should come along with it.
  15. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 15、 2の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 15、 2の画像 2
    • With the hammer rod side of the bullet chamber facing you, unscrew the 5 mm phillips screw holding the hammer rod in place.
  16. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: 手順 16、 1の画像 1
    • Remove the hammer rod.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Elizabeth Coffey
メンバー登録日: 01/26/14
404 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-35, Maness Winter 2014 Cal Poly, Team 10-35, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G35
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 7,470
