はじめに
If the firing spring becomes dislodged or damaged, your rifle may have reduced firing ability, or may not fire at all. This guide shows you how to access and replace the primary firing spring in the Nerf N-Strike Elite Alpha Trooper CS-12.
This guide may also be used when upgrading the firing spring on your rifle.
  1. There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
    • There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
    • Be sure that the rifle is discharged and unloaded before starting disassembly.
  2. Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle. Pull off the orange cap. Pull off the orange cap.
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together. Remove the three 10 mm phillips screws from the bottom of the slide mechanism. Separate and remove the two halves of the slide mechanism.
    • With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  5. Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle. Remove the two 5 mm phillips screws from the main body.
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  6. Pull the two halves of the rifle apart. Be careful of the spring at the rear end of the rifle. It may come flying out. If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  7. You should now be able to pull the main firing spring from the rear of the rifle.
    • You should now be able to pull the main firing spring from the rear of the rifle.
まとめ
2 の人々がこのガイドを完成させました。
Henrique Chan
メンバー登録日: 2014年01月24日
285 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-35, Maness Winter 2014 Cal Poly, Team 10-35, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G35
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 59
今までの合計 3,981
