メインコンテンツにスキップ
Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement
必要な工具と部品
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: 手順 1、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: 手順 1、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: 手順 1、 3の画像 3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: 手順 2、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: 手順 2、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: 手順 2、 3の画像 3
    • With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 3、 2の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 3、 2の画像 2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 4、 3の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 4、 3の画像 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 4、 3の画像 3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, use a spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 5、 2の画像 1 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 5、 2の画像 2
    • Remove the two 5mm phillips screws from the rifle muzzle.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 6、 1の画像 1
    • Remove the muzzle and barrel from the rifle body.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 手順 7、 1の画像 1
    • Separate the muzzle from the barrel.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Elizabeth Coffey
メンバー登録日: 01/26/14
404 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-35, Maness Winter 2014 Cal Poly, Team 10-35, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G35
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 5,849
