メインコンテンツにスキップ
Nerf N-Strike Deploy CS-6 Dart Tooth Replacement
必要な工具と部品
  1. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement, Dart Tooth: 手順 1、 1の画像 1
    • Before releasing the device in Stealth mode, take out hidden screws as shown
    • Extend the device in Stealth Mode by pressing the button found on the handle.
  2. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 2、 3の画像 1 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 2、 3の画像 2 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 2、 3の画像 3
    • Take out the screws from the pump.
    • Proceed to take out the other screws from the device to take off the cover.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 3、 2の画像 1 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 3、 2の画像 2
    • Once the screws are out, you are able to take the cover piece off.
    • Proceed to remove the screws
    • Taking off those screws are vital in replacing the dart tooth.
  4. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 4、 1の画像 1
    • Carefully place cover piece above the device.
  5. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 5、 1の画像 1
    • Unscrew as shown to aid in the replacement.
  6. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 6、 1の画像 1
    • To take out the dart tooth, push the spring to the left.
    • The dart tooth should pop out with ease.
  7. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 7、 1の画像 1
    • Once pulled away from the device, take off the orange piece connected to the darth tooth
    • The piece can be identified with the spring.
  8. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 8、 1の画像 1
    • You should now be able to pull apart the dart tooth from the device.
    • The piece that has been pulled away will have a type of lubrication. If this piece requires replacement, it will slide on with ease.
  9. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 9、 1の画像 1
    • Make any adjustment to the dart tooth as seen. May be pulled either up or down.
    • Place in the replacing piece in order to fix the darth tooth
  10. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 10、 3の画像 1 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 10、 3の画像 2 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 10、 3の画像 3
    • Place back on the orange piece with the spring to its original spot on the dart tooth.
    • While setting in the dart tooth back into place, the small spring on the yellow piece must be placed in its compartment as shown.
    • Place back cover pieces in order to secure the screws back into place.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Alec Hernandez
メンバー登録日: 09/28/16
126 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 2-5, Mathisen Fall 2016 Eastern Washington University, Team 2-5, Mathisen Fall 2016人のメンバー
EWU-MATHISEN-F16S2G5
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 3,125
