メインコンテンツにスキップ
Nerf Dart Tag Furyfire Trigger Replacement
必要な工具と部品
  1. Nerf Dart Tag Furyfire Trigger Replacement, Remove the screws: 手順 1、 1の画像 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Trigger Replacement, Remove Panel: 手順 2、 1の画像 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Trigger Replacement, Remove Black Cylinder: 手順 3、 1の画像 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Trigger Replacement, Remove Spring: 手順 4、 2の画像 1 Nerf Dart Tag Furyfire Trigger Replacement, Remove Spring: 手順 4、 2の画像 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Trigger Replacement, Remove Pump Handle: 手順 5、 1の画像 1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Handle: 手順 6、 1の画像 1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Trigger Replacement, Remove Attached Spring: 手順 7、 2の画像 1 Nerf Dart Tag Furyfire Trigger Replacement, Remove Attached Spring: 手順 7、 2の画像 2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Trigger Replacement, Disengage White Piece: 手順 8、 1の画像 1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Track: 手順 9、 2の画像 1 Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Track: 手順 9、 2の画像 2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
  10. Nerf Dart Tag Furyfire Trigger Replacement, Detach Black Piece from Trigger: 手順 10、 1の画像 1
    • Using a plastic opening tool, detach the black piece from the trigger. You do not need to remove the black piece from the gun.
  11. Nerf Dart Tag Furyfire Trigger Replacement, Remove Trigger: 手順 11、 1の画像 1
    • Once the black piece has been detached, the trigger can be lifted out of the device.
終わりに
To reassemble your device, follow these instructions in reverse order. Ensure that the spring located behind the trigger is attached to the limb on the backside of the trigger.
作成者
3人の作成者と共同で作成されました。
Bradley Penrow
メンバー登録日: 09/23/14
37 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 11-2, Blackwell Fall 2014 USF Tampa, Team 11-2, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S11G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 766
