メインコンテンツにスキップ
Nerf Dart Tag Furyfire Pump Track Replacement
必要な工具と部品
  1. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the screws: 手順 1、 1の画像 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Panel: 手順 2、 1の画像 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Black Cylinder: 手順 3、 1の画像 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: 手順 4、 2の画像 1 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: 手順 4、 2の画像 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Pump Handle: 手順 5、 1の画像 1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Handle: 手順 6、 1の画像 1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: 手順 7、 2の画像 1 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: 手順 7、 2の画像 2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Pump Track Replacement, Disengage White Piece: 手順 8、 1の画像 1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: 手順 9、 2の画像 1 Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: 手順 9、 2の画像 2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Bradley Penrow
メンバー登録日: 09/23/14
37 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 11-2, Blackwell Fall 2014 USF Tampa, Team 11-2, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S11G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 460
