メインコンテンツにスキップ
Neo3Do Battery & LED screen Replacement
必要な工具と部品
  1. Neo3Do Battery & LED screen Replacement, Back Panel: 手順 1、 3の画像 1 Neo3Do Battery & LED screen Replacement, Back Panel: 手順 1、 3の画像 2 Neo3Do Battery & LED screen Replacement, Back Panel: 手順 1、 3の画像 3
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
  2. Neo3Do Battery & LED screen Replacement: 手順 2、 2の画像 1 Neo3Do Battery & LED screen Replacement: 手順 2、 2の画像 2
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
  3. Neo3Do Battery & LED screen Replacement: 手順 3、 2の画像 1 Neo3Do Battery & LED screen Replacement: 手順 3、 2の画像 2
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
  4. Neo3Do Battery & LED screen Replacement: 手順 4、 1の画像 1
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
  5. Neo3Do Battery & LED screen Replacement, Motherboard: 手順 5、 3の画像 1 Neo3Do Battery & LED screen Replacement, Motherboard: 手順 5、 3の画像 2 Neo3Do Battery & LED screen Replacement, Motherboard: 手順 5、 3の画像 3
    • Remove all the tape attached to the motherboard.
  6. Neo3Do Battery & LED screen Replacement: 手順 6、 3の画像 1 Neo3Do Battery & LED screen Replacement: 手順 6、 3の画像 2 Neo3Do Battery & LED screen Replacement: 手順 6、 3の画像 3
    • Pull out the black tabs using the plastic spudger.
    • All sockets that require the same step are marked in the first photo.
  7. Neo3Do Battery & LED screen Replacement: 手順 7、 2の画像 1 Neo3Do Battery & LED screen Replacement: 手順 7、 2の画像 2
    • Remove the wire belt from the socket.
  8. Neo3Do Battery & LED screen Replacement: 手順 8、 3の画像 1 Neo3Do Battery & LED screen Replacement: 手順 8、 3の画像 2 Neo3Do Battery & LED screen Replacement: 手順 8、 3の画像 3
    • Lift the black tab and then remove the wire belt.
  9. Neo3Do Battery & LED screen Replacement: 手順 9、 3の画像 1 Neo3Do Battery & LED screen Replacement: 手順 9、 3の画像 2 Neo3Do Battery & LED screen Replacement: 手順 9、 3の画像 3
  10. Neo3Do Battery & LED screen Replacement: 手順 10、 3の画像 1 Neo3Do Battery & LED screen Replacement: 手順 10、 3の画像 2 Neo3Do Battery & LED screen Replacement: 手順 10、 3の画像 3
    • Grip the side of the tab and pull upwards to remove it from the socket.
    • Gripping the wire belt and pulling upwards may cause damage, be sure to avoid it.
  11. Neo3Do Battery & LED screen Replacement: 手順 11、 2の画像 1 Neo3Do Battery & LED screen Replacement: 手順 11、 2の画像 2
    • Remove the screws using the J0 head screwdriver.
    • All screws that require the same step are marked in the first photo.
  12. Neo3Do Battery & LED screen Replacement: 手順 12、 3の画像 1 Neo3Do Battery & LED screen Replacement: 手順 12、 3の画像 2 Neo3Do Battery & LED screen Replacement: 手順 12、 3の画像 3
    • Grip the active(red) wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
    • Repeat the same process to remove the neutral(black) wire.
    • All wires that require the same steps are marked in the first photo.
    • The soldering tool is extremely hot, use with caution.
  13. Neo3Do Battery & LED screen Replacement: 手順 13、 3の画像 1 Neo3Do Battery & LED screen Replacement: 手順 13、 3の画像 2 Neo3Do Battery & LED screen Replacement: 手順 13、 3の画像 3
    • Use the flat end of the plastic spudger to remove the motherboard and turn it underside-up.
  14. Neo3Do Battery & LED screen Replacement: 手順 14、 2の画像 1 Neo3Do Battery & LED screen Replacement: 手順 14、 2の画像 2
    • Remove the plug from the motherboard socket.
  15. Neo3Do Battery & LED screen Replacement: 手順 15、 3の画像 1 Neo3Do Battery & LED screen Replacement: 手順 15、 3の画像 2 Neo3Do Battery & LED screen Replacement: 手順 15、 3の画像 3
    • Grip the wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
  16. Neo3Do Battery & LED screen Replacement, Battery & LED screen: 手順 16、 2の画像 1 Neo3Do Battery & LED screen Replacement, Battery & LED screen: 手順 16、 2の画像 2
    • Remove the screws with a J000 screwdriver
  17. Neo3Do Battery & LED screen Replacement: 手順 17、 2の画像 1 Neo3Do Battery & LED screen Replacement: 手順 17、 2の画像 2
    • Use the plastic removal tool to remove the plastic frame.
  18. Neo3Do Battery & LED screen Replacement: 手順 18、 3の画像 1 Neo3Do Battery & LED screen Replacement: 手順 18、 3の画像 2 Neo3Do Battery & LED screen Replacement: 手順 18、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using the plastic removal tool, lift the LED screen from the battery side, and use the tweezers to help lift the LED screen upwards.
終わりに
作成者
2人の作成者と共同で作成されました。
Daniel Evans
メンバー登録日: 09/26/16
431 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 14-3, Eyestone Fall 2016 USF Tampa, Team 14-3, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S14G3
3 メンバー
12のガイドは作成済み
コメント 1 件
Do you have a source for Neo3DO Digitizer replacement.
Chris - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 205
