メインコンテンツにスキップ
Necklace Barrel Clasp Repair
必要な工具と部品
  1. Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: 手順 1、 2の画像 1 Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: 手順 1、 2の画像 2
    • Locate the broken part of the ring that attaches through the back of the barrel clasp.
    • Bend the portion of the ring with needle nose pliers until the newly compact ring can be pushed through the barrel clasp and fit snug.
  2. Necklace Barrel Clasp Repair: 手順 2、 1の画像 1
    • Plug in the electric soldering iron and set the solder temperature to the degrees that suits the melting point of both the soldering wire and the barrel clasp.
    • The soldering iron tip can get extremely hot and will cause severe burns if comes into direct contact with skin. Ensure you keep a safe distance, and wear safety equipment.
    • This method is not recommended for precious metals.
  3. Necklace Barrel Clasp Repair: 手順 3、 1の画像 1
    • Molten metal is extremely hot and will cause severe burns. Handle the soldering gun with care and keep your distance from the melting metal.
    • Solder the base of the barrel clasp where the metal ring fits in, intersecting the tips of the soldering gun and soldering wire.
    • Ensure the barrel clasp and ring connection is covered, allowing anywhere from 10 to 30 seconds for the bond to harden and cool.
  4. Necklace Barrel Clasp Repair: 手順 4、 1の画像 1
    • Attach the barrel clasp necklace back together and hold each end of the necklace taught to test the solder strength.
    • Do not pull too hard—the amount of strain may cause the solder to break.
終わりに
作成者
3人の作成者と共同で作成されました。
Garrett Key
メンバー登録日: 07/12/17
107 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S1-G5, Rauch Summer 2017 Texas Tech, Team S1-G5, Rauch Summer 2017人のメンバー
TTU-RAUCH-SU17S1G5
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 36
今までの合計 2,701
