メインコンテンツにスキップ
Neato Botvac D75 Motherboard Replacement
必要な工具と部品
  1. Neato Botvac D75 Motherboard Replacement, Battery: 手順 1、 3の画像 1 Neato Botvac D75 Motherboard Replacement, Battery: 手順 1、 3の画像 2 Neato Botvac D75 Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
    • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
  2. Neato Botvac D75 Motherboard Replacement: 手順 2、 3の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 2、 3の画像 2 Neato Botvac D75 Motherboard Replacement: 手順 2、 3の画像 3
    • Lift battery cover out.
  3. Neato Botvac D75 Motherboard Replacement: 手順 3、 3の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 3、 3の画像 2 Neato Botvac D75 Motherboard Replacement: 手順 3、 3の画像 3
    • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
    • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
  4. Neato Botvac D75 Motherboard Replacement, Brushes: 手順 4、 3の画像 1 Neato Botvac D75 Motherboard Replacement, Brushes: 手順 4、 3の画像 2 Neato Botvac D75 Motherboard Replacement, Brushes: 手順 4、 3の画像 3
    • To remove the rotary brush simply grasp it firmly and pull it off.
  5. Neato Botvac D75 Motherboard Replacement: 手順 5、 3の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 5、 3の画像 2 Neato Botvac D75 Motherboard Replacement: 手順 5、 3の画像 3
    • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
    • With a little force it should come out.
    • The boxes show you were the clips are that hold this piece
  6. Neato Botvac D75 Motherboard Replacement: 手順 6、 1の画像 1
    • Once the black piece has been taken out, the brush just comes out easily.
  7. Neato Botvac D75 Motherboard Replacement, LCD Screen: 手順 7、 2の画像 1 Neato Botvac D75 Motherboard Replacement, LCD Screen: 手順 7、 2の画像 2
    • Firmly grasp the back cover and pull away from the Botvac one side at a time.
    • Removing the cover will expose two 1.3mm T10 screws that must be removed to separate the cover halves.
  8. Neato Botvac D75 Motherboard Replacement: 手順 8、 2の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 8、 2の画像 2
    • Remove these two 13mm T10 screws. You will need to use the extension in your tool set since they are deep in the casting.
  9. Neato Botvac D75 Motherboard Replacement: 手順 9、 2の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 9、 2の画像 2
    • Eight 13mm T10 screws on the underside of the Botvac hold the casing together. These screws are not self-retained so make sure that you don’t lose them in the disassembly process.
  10. Neato Botvac D75 Motherboard Replacement: 手順 10、 3の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 10、 3の画像 2 Neato Botvac D75 Motherboard Replacement: 手順 10、 3の画像 3
    • The screws pictured here on either side of the Botvac require the extension in your tool set to be removed.
  11. Neato Botvac D75 Motherboard Replacement: 手順 11、 2の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 11、 2の画像 2
    • On the back of the Botvac there are two retaining tabs that must be pressed to be released.
    • With the tabs released the top and bottom cover halves can be separated.
  12. Neato Botvac D75 Motherboard Replacement: 手順 12、 3の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 12、 3の画像 2 Neato Botvac D75 Motherboard Replacement: 手順 12、 3の画像 3
    • Carefully lift the top cover of the Botvac. On the right side of the Botvac is where you'll find the LCD screen connector to the motherboard. Carefully pull on the connector to disconnect it from the motherboard.
  13. Neato Botvac D75 Motherboard Replacement: 手順 13、 3の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 13、 3の画像 2 Neato Botvac D75 Motherboard Replacement: 手順 13、 3の画像 3
    • There are two 0.5cm #1 Phillips screws holding the LCD screen to the top cover. Remove these screws to lift screen off the cover.
  14. Neato Botvac D75 Motherboard Replacement: 手順 14、 3の画像 1 Neato Botvac D75 Motherboard Replacement: 手順 14、 3の画像 2 Neato Botvac D75 Motherboard Replacement: 手順 14、 3の画像 3
    • With the two screws removed you may lift the screen off the cover. Carefully remove the connector from the screen by pulling on the connector.
  15. Neato Botvac D75 Motherboard Replacement, Motherboard: 手順 15、 3の画像 1 Neato Botvac D75 Motherboard Replacement, Motherboard: 手順 15、 3の画像 2 Neato Botvac D75 Motherboard Replacement, Motherboard: 手順 15、 3の画像 3
    • Carefully remove the plugs connected to top side of the motherboard.
    • Be careful to not pull the white casings that attach the plugs to the board.
  16. Neato Botvac D75 Motherboard Replacement: 手順 16、 1の画像 1
    • Remove the cables attached to the under side of the motherboard.
    • Similarly to the previous step, be careful as to not remove the casing attaching the cable to the board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Juan Cornejo
メンバー登録日: 02/15/17
597 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S6-G5, Lacy Spring 2017 USF Tampa, Team S6-G5, Lacy Spring 2017人のメンバー
USFT-LACY-S17S6G5
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 37
今までの合計 4,831
