はじめに
This guide will explain how to properly replace the display screen on the top of your Neato Botvac Connected.
必要な工具と部品
Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
Remove the four screws lining the front roller using a TR10 Torx screwdriver.
Remove the black panel behind and in front of the roller.
Gently lift the roller by the right side to remove it.
もう少しです!
終わりに
