メインコンテンツにスキップ
Neato Botvac 80 Wheel Replacement
必要な工具と部品
  1. Neato Botvac 80 Wheel Replacement, Rear Bumper: 手順 1、 1の画像 1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac 80 Wheel Replacement: 手順 2、 1の画像 1
    • Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
  3. Neato Botvac 80 Wheel Replacement, Top Face Panel: 手順 3、 2の画像 1 Neato Botvac 80 Wheel Replacement, Top Face Panel: 手順 3、 2の画像 2
    • Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
  4. Neato Botvac 80 Wheel Replacement: 手順 4、 1の画像 1
    • Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
  5. Neato Botvac 80 Wheel Replacement: 手順 5、 3の画像 1 Neato Botvac 80 Wheel Replacement: 手順 5、 3の画像 2 Neato Botvac 80 Wheel Replacement: 手順 5、 3の画像 3
    • To remove the top, you must press in both of the clamps at the same time and push upwards.
    • When removing the top, before you can completely take it off you must unplug the LCD power cable from the motherboard.
  6. Neato Botvac 80 Wheel Replacement, Wheels: 手順 6、 3の画像 1 Neato Botvac 80 Wheel Replacement, Wheels: 手順 6、 3の画像 2 Neato Botvac 80 Wheel Replacement, Wheels: 手順 6、 3の画像 3
    • Locate the screws that mount the wheel extensions on the Botvac.
    • Unscrew the four 11mm screws and bolts indicated to remove the frame.
    • The metallic weight (as shown) does not require the removal of any screws. However, make sure to complete this before proceeding.
  7. Neato Botvac 80 Wheel Replacement: 手順 7、 2の画像 1 Neato Botvac 80 Wheel Replacement: 手順 7、 2の画像 2
    • Gently lift the frame holding the laser. This will free the wheels from their casing.
    • Remove the wheel's wires that are attached to the motherboard.
    • Once removed, you may now free the wheels.
  8. Neato Botvac 80 Wheel Replacement: 手順 8、 3の画像 1 Neato Botvac 80 Wheel Replacement: 手順 8、 3の画像 2 Neato Botvac 80 Wheel Replacement: 手順 8、 3の画像 3
    • Remove the wheel usings the T15, or similar, attachment to remove the 32.5mm screw.
    • Finally, just grab and separate the tire from its axle.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brandon Blank
メンバー登録日: 02/02/17
675 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 17-5, Blackwell Spring 2017 USF Tampa, Team 17-5, Blackwell Spring 2017人のメンバー
USFT-BLACKWELL-S17S17G5
3 メンバー
12のガイドは作成済み
8 件のコメント
After this fix, it just says to put it in the floor. Is there a sensor or withat I may have missed connecting?
Sandra Me - 返信
are left and right rear wheels identical parts? can one just replace the wheels and not the motors? I have loose ratcheting in one of the rear wheels. the D80 won’t back up correctly and stalls at each chair.
Dennis Abramsohn - 返信
I have a Neato D7 and I am replacing the wheels. I have pulled it apart and mistakenly didn’t take a picture prior to disassembling the same area you did with the 80. Do you at least have a diagram of the D7 that I could use to re-assemble? I am particularly concerned about where the springs and a circular piece connected to circuit board (labeled 8015W) is placed.
Thanks
cornishpd - 返信
The tread on my botvac 80 is gone on 1 back wheel. Motor seems to still work good. Can you tell me how to get a replacement wheel? Have looked on amazon and ebay. Any help will be appreciated. Tammy
Lucky charms LeFlohic - 返信
Taking apart and assembly is the easy part. Finding spares however… Got a worn down drive gear, that’s it. The rest of the machine seems just fine. So a $4-500 gadget is broken just because I can’t find a small plastic gear replacement that shouldn’t be more than a few bucks. Stupid.
Jens B. - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 23
今までの合計 9,374
