メインコンテンツにスキップ
Neato BOTVAC CONNECTED Side Wheel Replacement
必要な工具と部品
  1. Neato BOTVAC CONNECTED Side Wheel Replacement, Battery: 手順 1、 1の画像 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 2、 2の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 2、 2の画像 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 3、 2の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 3、 2の画像 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 4、 3の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 4、 3の画像 2 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 4、 3の画像 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 5、 1の画像 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: 手順 6、 2の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: 手順 6、 2の画像 2
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 7、 1の画像 1
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 8、 1の画像 1
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 9、 1の画像 1
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 10、 1の画像 1
    • Gently remove the front brush.
  11. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: 手順 11、 2の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: 手順 11、 2の画像 2
    • Gently twist the side brush back and forth.
  12. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 12、 3の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 12、 3の画像 2 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 12、 3の画像 3
    • Spin the side brush counter counterclockwise.
  13. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 13、 1の画像 1
    • Use the spudger to gently pry up and remove the side brush.
  14. Neato BOTVAC CONNECTED Side Wheel Replacement, Filter: 手順 14、 1の画像 1
    • Flip the cleaner around and locate the front panel.
  15. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 15、 1の画像 1
    • Gently remove the front panel by opening it with a spudger.
  16. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 16、 2の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 16、 2の画像 2
    • Use the spudger to gently remove the paper filter.
  17. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Wheel: 手順 17、 1の画像 1
    • Remove the following screws with a TR10 Torx screwdriver:
    • Six 2.3 mm screws.
  18. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 18、 2の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 18、 2の画像 2
    • Remove the front bumper by pulling it horizontally on each side.
  19. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 19、 1の画像 1
    • Remove the screw that is directly attached to the wheel on the side using a Phillips #2 screwdriver.
  20. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 20、 1の画像 1
    • Remove the two 2.3 mm screws on the front of the vacuum with a TR10 Torx screwdriver.
  21. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 21、 1の画像 1
    • Remove the layer below the front bumper by pressing firmly on the two levers located nearby.
  22. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 22、 3の画像 1 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 22、 3の画像 2 Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 22、 3の画像 3
    • Gently take out the top panel, and take out the connecting wires.
  23. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 23、 1の画像 1
    • Two 2.3 mm screws.
  24. Neato BOTVAC CONNECTED Side Wheel Replacement: 手順 24、 1の画像 1
    • Flip around the vacuum and remove the wheel with the spudger.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Justin Silva
メンバー登録日: 03/20/23
645 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 6-3, Botvin Spring 2023 UMass Dartmouth, Team 6-3, Botvin Spring 2023人のメンバー
UMASSD-BOTVIN-S23S6G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 8
過去 30 日: 20
今までの合計 241
