はじめに
The battery is one of the most important components of any portable device, because without power, the device will not be able to function. The battery equipped in the DreamTab resembles an aluminum foil-wrapped chocolate bar which is very malleable. The battery itself is attached to the device using strong adhesive, so it is important to remove the battery with care as it will bend if excessive force is used. We recommend using the metal opening tools only if the plastic opening tools don’t provide enough leverage to remove the battery from the adhesive.
必要な工具と部品
Position the Nabi DreamTab onto a non-metallic surface so that the screen is facing towards the ceiling, and the DreamTab logo appears closest to you.
Remove the red silicone case from the Nabi DreamTab HD8.
Rotate the top of the device towards you so that the audio jack appears on the right side of the device.
Wedge the plastic opening tool between where the front and back case panels meet near the audio jack.
Pry the device open using moderate force until you hear a clicking sound. This is the sound of the clips unlocking.
Move along the perimeter of the entire device using the same prying motion to gradually separate the front and back panels.
Once the edges are open return to the same starting position next to the audio jack.
Disconnect the final battery connector from the motherboard.
Remove the battery.
Is there any site to buy this battery
Is it have battery
2 の人々がこのガイドを完成させました。
8 件のコメント
Great directions. Good to know stuff. Where, if I may ask, did you find the replacement battery. Thanks in advance, and, keep on keeping on.
Jim Osburn - 返信
The inside of my DreamTab looks NOTHING like this. For one, the battery is NOT foil wrapped. Other than that, still nothing like your pictures.
There are two different DreamTab models: DMTAB-IN08A and DMTAB-NV08B.
This procedure is using the DMTAB-NV08B.
Restaure mi nabi dream 8 pero ahora no puedo acceder a mi correo me dice , comprobando disponibilidad y no pasa de ahi
Very good instructions
Very good instructions the pictures a bunch of help as well as the notes about being careful
This battery available in any online site
